Inkplate 6COLOR – Free GPIO pins
Inkplate 6COLOR's onboard ESP32 WROVER-E has some pins reserved for internal use (for example, the connection to the e-paper display) and cannot be used for end-user applications. This page contains a list of the available GPIO pins that can be used for external applications.
If you don't need pin details and are just interested in the pins, here are the Inkplate 6COLOR pins that are not connected to any external component:
ESP32: IO2, IO4, IO5, IO25, IO26, GPIO EXPANDER: P0-0 to P1-7
Inkplate 6color free pins
Free pin table
| PIN | CONNECTED TO | FUNCTION |
| TXD | CH340 | UART transmit pin |
| RXD | CH340 | UART receive pin |
| IO12 | SDCARD | ADC2_CH5, TOUCH5, RTC_GPIO15, MTDI, HSPIQ, HS2_DATA2, SD_DATA2, EMAC_TXD3 |
| IO13 | SDCARD | ADC2_CH4, TOUCH4, RTC_GPIO14, MTCK, HSPID, HS2_DATA3, SD_DATA3, EMAC_RX_ER |
| IO14 | SDCARD | ADC2_CH6, TOUCH6, RTC_GPIO16, MTMS, HSPICLK, HS2_CLK, SD_CLK, EMAC_TXD2 |
| IO15 | JP6 Check jumper details | ADC2_CH3, TOUCH3, MTDO, HSPICS0, RTC_GPIO13, HS2_CMD, SD_CMD, EMAC_RXD3 |
| IO34 | JP1 Check jumper details | ADC1_CH6, RTC_GPIO4 |
| IO35 | V_BAT | ADC1_CH7, RTC_GPIO5 |
| IO36 | WAKEUP BUTTON | ADC1_CH0, RTC_GPIO0 |
| IO39 | JP5 Check jumper details | ADC1_CH3, RTC_GPIO3 |
| IO2 | FREE | ADC2_CH2, TOUCH2, RTC_GPIO12, HSPIWP, HS2_DATA0, SD_DATA0 |
| IO4 | FREE | ADC2_CH0, TOUCH0, RTC_GPIO10, HSPIHD, HS2_DATA1, SD_DATA1, EMAC_TX_ER |
| IO5 | FREE | VSPICS0, HS1_DATA6, EMAC_RX_CLK |
| IO25 | FREE | DAC_1, ADC2_CH8, RTC_GPIO6, EMAC_RXD0 |
| IO26 | FREE | DAC_2, ADC2_CH9, RTC_GPIO7, EMAC_RXD1 |
| P0-0 TO P1-7 | FREE | SD_DATA1, EMAC_TX_ER |
