Hardware details
Pinout​
NULA Core pinout
NULA Core Pinout Diagram
Pin Details​
VBATPowerBattery input for 3.7 V Li-Ion/Li-Poly battery through the JST connector.
VCCPowerMain power input (5 V via USB-C or external 5 V supply).
3V3PowerRegulated 3.3 V output from the onboard regulator.
RESETControlHardware reset pin.
D0-D13/A0-A7GPIOGeneral-purpose I/O pins, supporting PWM, I²C, SPI, UART, ADC.
A0-A5 can be used as Digital IO pins, but A6/A7 are analog-only inputs.
Qwiic / easyC Connector​
Qwiic/easyC connector
The NULA Core includes a Qwiic/easyC/STEMMA QT connector for quick plug-and-play connections with I²C devices such as sensors and peripherals.
Learn more about Qwiic hardware compatibility and connector pinout.
Power Supply and Battery​
  • USB-C Port is used for both programming and powering the board
  • VBAT (JST connector) is used for connecting a 3.7 V Li-Ion or Li-Poly battery
  • The board includes an integrated Li-Ion charge management circuit
  • Operating voltage: 3.3 V (onboard regulator for 5 V input)
When powered using a battery, the onboard charger automatically handles charging and discharging.
For 5 V input, always power the board through the USB-C port.
Dimensions​
  • Board size: 63 x 22 mm / 2.5 x 0.9 inch
  • Mounting: Breadboard compatible
  • Header Pin Holes: 1.5 mm
Soldered boards are LEGO compatible! 🧱
Jumper Details​
Loading carousel...
JumperDefault StateFunction
JP1NC (Normally closed)Disconnects the Power LED to reduce standby current draw when running from battery power.
JP2NC (Normally closed)Connects the 5 V I²C pull-up resistors for SDA and SCL lines when required by connected I²C devices.
JP3NC (Normally closed)Connects the 3.3 V I²C pull-up resistors for SDA and SCL lines when required by connected I²C devices.
Hardware repository​
NULA-Core-hardware-design
CAD files​
Schematic​
BOM (Bill of Materials)​
3D files​
Gerber files​
Compliance​
