Overview
USB-C PD Breadboard power supply​
The USB-C PD Breadboard Power Supply plugs into any USB-C PD adapter and uses the onboard HUSB238 controller to negotiate the output voltage and current you select with the hardware switches. Supported voltages run from 5V to 20V, with current limits up to 3.25A. Output is available on pin headers and a terminal block, with an ON/OFF switch and a power LED on board.
Image coming soon.
Product link coming soon.
Key features​
  • USB-C input with ON/OFF switch
  • HUSB238 USB-PD sink controller
  • Output voltage: 5V, 9V, 12V, 15V, or 20V (switch selectable)
  • Current limit: 1.25A, 1.5A, 2A, 2.5A, 3A, or 3.25A (switch selectable)
  • Power LED indicator
  • SDA and SCL pins broken out for I2C access
