Overview
NULA Core​
Start building your next Arduino-based project with NULA Core, a compact yet fully featured development board designed for makers of all skill levels. With full Arduino IDE compatibility it brings the classic Arduino Uno experience in a much smaller and more project-friendly size.
Powered by the famous Atmel ATmega328P, NULA Core provides 22 I/O pins (14 digital + 8 analog), making it suitable for everything from simple electronics experiments to more advanced projects. Its built-in USB Type-C connector ensures easy programming and reliable power delivery.
Designed for modern and fast prototyping, NULA Core includes a Qwiic connector for effortless I²C expansion, an onboard 3.3 V regulator for powering sensors and breakouts, and a Li-Ion battery charger with connector for portable applications. It also features a WS2812B RGB LED, giving your projects an instant visual upgrade right out of the box.
NULA Core
NULA Core Development Board
NULA Core
NULA Core
Simple and compact board that will perform all kinds of tasks, all while taking up very little space.
Key Features​
  • Microcontroller: ATmega328P (8-bit AVR) @ 16 MHz
  • Operating Voltage: 5 V logic level
  • GPIO: 22 pins (14 digital, 8 analog)
  • Communication Interfaces: UART, SPI, and I²C supported
  • USB-C Connector: USB Type-C for programming, power and serial communication
  • Battery Support: Li-Ion battery connector with onboard charging circuit
  • 3.3 V Regulator: Dedicated 3.3 V output for powering sensors and breakouts
  • Compatibility: 100% compatible with Arduino boards and Arduino IDE
  • Qwiic Connector: Plug-and-play I²C connector for fast prototyping
  • Onboard Features: Dedicated User and Reset buttons + onboard WS WS2812B RGB LED
  • Form Factor: Compact breakout board design (smaller than Arduino Uno)
You may also need​
Qwiic cable
Qwiic cable
Li-Ion Battery 3.7 V
Rechargeable 3.7 V Li-Ion battery compatible with NULA Max’s JST connector.
