Hardware details
Pinout​
Pinout
Pin details​
VOUTVoltage OutNegotiated output voltage supplied to the breadboard and terminal block.
GNDGroundCommon ground.
SDAI2C DataOptional I2C data line for dynamic configuration of the HUSB238 chip.
SCLI2C ClockOptional I2C clock line for dynamic configuration of the HUSB238 chip.
Jumper details​
Image coming soon.
JumperDefault StateFunction
JP1NC (Normally closed)When shorted, it provides power to the onboard power LED
Switch details​
Voltage selection switch and current selection switches control power and output:
Images coming soon.
SwitchFunction
ON/OFF SwitchSwitches power to the board on or off.
Voltage SelectionHardware switches used to request standard USB-PD voltage levels (5V, 9V, 12V, 15V, 20V).
Current SelectionHardware switches used to set the current limit (1.25A, 1.5A, 2A, 2.5A, 3A, 3.25A).
Dimensions​
  • Board Dimensions: 54 x 30mm (2.1 x 1.2 inches)
  • Header Pin Holes: 1.5 mm
  • Soldered boards are LEGO-compatible! 🧱
HUSB238 USB-PD Controller​
The HUSB238 is the USB Power Delivery sink controller on this board. It negotiates standard PD voltage steps and current limits from a USB-C source using hardware switch inputs, no external software or microcontroller needed.
Hardware repository​
Hardware repository link coming soon.
The output folders are versioned. You can find which board version you have by checking the version mark on the PCB.
CAD files​
We use KiCad, an open-source PCB design tool. You can open and edit the .kicad_pcb and .kicad_sch files to inspect the board design in CAD software.
Gerber files​
The repository includes standard Gerber outputs in a .zip file:
  • Copper layers (.Cu.gbr): Defines the traces and pads on the board.
  • Solder mask layers (.Mask.gbr): Specifies the protective solder mask.
  • Silkscreen layers (.Silkscreen.gbr): Contains text and component markings.
  • Paste layers (.Paste.gbr): Used for stencil fabrication in SMD assembly.
  • Drill files (.drl): Provides drilling coordinates for vias and holes.
  • Board outline (.Edge_Cuts.gbr): Defines the shape of the PCB.
  • Gerber job file (.gbrjob): Describes the set of Gerber files used for production.
Compliance​
Regulatory and safety documents for this product:
  • CE: Certification document confirming compliance with EU safety, health, and environmental requirements.
  • UKCA: UKCA (UK Conformity Assessed) certification for the UK market.
  • Safety Instructions: Safety guidelines and precautions provided in English and German.
  • Info.txt: Contains product details such as SKU, country of origin, HS tariff code, and barcode.
