Hardware details
Pinout​
Inputronic BRIDGE pinout diagram
Pin details​
3V33.3V Power3.3V power supply input for logic.
GNDGroundCommon ground for the module.
SDAI2C DataI2C data line for the default communication protocol.
SCLI2C ClockI2C clock line for the default communication protocol.
RXUART ReceiveUART receive pin (used when UART protocol is selected).
TXUART TransmitUART transmit pin (used when UART protocol is selected).
MISOSPI MISOSPI Master In Slave Out pin (used when SPI protocol is selected).
MOSISPI MOSISPI Master Out Slave In pin (used when SPI protocol is selected).
CLKSPI ClockSPI Clock pin (used when SPI protocol is selected).
CSSPI Chip SelectSPI Chip Select pin (used when SPI protocol is selected).
INTInterrupt OutputSignals the host MCU when new data is ready (avoids continuous polling).
IO0GPIO 0ESP32-S3 boot/strap pin, also available as general I/O.
FAULTFault IndicatorOvercurrent fault output from the USB protection switch.
RSTResetActive-low reset pin for the onboard ESP32-S3.
This board contains hardware jumpers, see below for their locations and functions:
Loading carousel...
Jumper MarkingDefault StateDescription
JP1NC (Normally closed)Cut the trace to disconnect the power LED and reduce overall current consumption.
JP2NC (Normally open)Connects the onboard 3.3V pull-up resistors for the I2C bus (SDA and SCL) by default. Cut this trace if you want to disconnect them.
JP3NO (Normally open)Configures the output protocol. Leave open for default I2C, or solder to select UART/SPI modes.
JP4NO (Normally open)Configures the output protocol. Leave open for default I2C, or solder to select UART/SPI modes.
The table below shows how JP3 and JP4 configure the module's communication protocol.
JP3JP4Active Protocol
Not connectedNot connectedI2C
ConnectedNot connectedUART
Not connectedConnectedUART
ConnectedConnectedSPI
Dimensions​
  • Board Dimensions: 63 x 26 mm (2.48 x 1.02 inch)
  • Header Pin Holes: 1.5 mm
Hardware Repository​
Inputronic Hardware Design
CAD files​
Schematic​
BOM (Bill of Materials)​
3D files​
Gerber files​
  • Copper layers (.Cu.gbr) - Defines the traces and pads on the board.
  • Solder mask layers (.Mask.gbr) - Specifies the protective solder mask.
  • Silkscreen layers (.Silkscreen.gbr) - Contains text and component markings.
  • Paste layers (.Paste.gbr) - Used for stencil fabrication in SMD assembly.
  • Drill files (.drl) - Provides drilling coordinates for vias and holes.
  • Board outline (.Edge_Cuts.gbr) - Defines the shape of the PCB.
  • Gerber job file (.gbrjob) - Describes the set of Gerber files used for production.
Compliance​
  • CE - Certification document confirming compliance with EU safety, health, and environmental requirements.
  • UKCA - UKCA (UK Conformity Assessed) certification for the UK market.
  • Safety Instructions - Safety guidelines and precautions in English and German.
  • Info.txt - Contains product details such as SKU, country of origin, HS tariff code, and barcode.
