Getting started
Arduino library​
To install the Arduino library for the Inputronic BRIDGE, you can use the Arduino Library Manager or download it from the GitHub repository:
Soldered Inputronic BRIDGE Arduino library
Inputronic BRIDGE parser and communication helper for UART, I2C, and SPI.
Getting started with Arduino
Connections​
Below are example connection diagrams for Nula DeepSleep. These pins will be used in the examples throughout this documentation.
I2C Connection (Default)​
The easiest way to connect the Inputronic BRIDGE to the Nula DeepSleep is using the onboard Qwiic (formerly easyC) system.
Nula DeepSleepInputronic BRIDGE
Qwiic ConnectorQwiic Connector
If you prefer, you can use the standard header pins to manually connect via I2C:
3V33V3
GNDGND
IO8 (Standard SDA pin)SDA
IO9 (Standard SCL pin)SCL
Module connection using qwiic cable
UART Connection​
If you have selected the UART protocol via the onboard jumpers (JP3 & JP4), use the following connections:
3V33V3
GNDGND
RXTX
TXRX
SPI Connection​
If you have selected the SPI protocol via the onboard jumpers (JP3 & JP4), use the following connections (using standard ESP32-S3 FSPI pins):
3V33V3
GNDGND
IO11 (Standard MOSI pin)MOSI
IO13 (Standard MISO pin)MISO
IO12 (Standard SCK pin)CLK
IO10 (Standard CS pin)CS
Optional Pins​
Nula DeepSleepInputronic BRIDGEDescription
Any Digital Pin (e.g., IO4)INTConnect for interrupt-driven event reading to save host CPU cycles.
