Hardware details
Pinout​
Pinout
Pin Details​
3V3Debug Power3.3V power supply for debugging purposes.
UPDIDebug InterfaceUsed for debugging and programming the onboard ATTiny404 microcontroller.
GNDDebug GroundGround pin for debugging purposes.
Power Consumption​
The power consumption of the Inputronic GRID depends heavily on the state and brightness of the 16 onboard RGB LEDs. The board operates on a 3.3V supply.
When all 16 RGB LEDs are turned on at full brightness (pure white) and the microcontroller is actively scanning:
  • 16x WS2812B-2020 LEDs: ~160mA (approx. 10mA per LED)
  • ATtiny404 Microcontroller: ~5mA
  • Total Current: ~165mA
Dimensions​
  • Board Dimensions: 60mm x 60mm (2.36 x 2.36 inch)
  • Header Pin Holes: 1.5 mm
Hardware repository​
The link for this repository has not been generated yet! We're working on it!
The hardware repository contains everything you need to understand, modify, or manufacture the board. The different output folders are versioned. You can check which board version you have by finding the version mark on the PCB.
CAD files​
Schematic​
BOM (Bill of Materials)​
3D files​
Gerber files​
  • Copper layers (.Cu.gbr) - Defines the traces and pads on the board.
  • Solder mask layers (.Mask.gbr) - Specifies the protective solder mask.
  • Silkscreen layers (.Silkscreen.gbr) - Contains text and component markings.
  • Paste layers (.Paste.gbr) - Used for stencil fabrication in SMD assembly.
  • Drill files (.drl) - Provides drilling coordinates for vias and holes.
  • Board outline (.Edge_Cuts.gbr) - Defines the shape of the PCB.
  • Gerber job file (.gbrjob) - Describes the set of Gerber files used for production.
Compliance​
  • CE - Certification document confirming compliance with EU safety, health, and environmental requirements.
  • UKCA - UKCA (UK Conformity Assessed) certification for the UK market.
  • Safety Instructions - Safety guidelines and precautions in English and in German.
  • Info.txt - Contains product details such as SKU, country of origin, HS tariff code, and barcode.
