Getting started
Arduino library​
Soldered Inputronic GRID Arduino library
Arduino Library for the Soldered Inputronic GRID device
Getting started with Arduino
Connections​
Below is an example connection diagram for NULA DeepSleep. These pins will be used in the examples throughout this documentation.
NULA DeepSleepBreakout Board
QwiicQwiic
The connection image for this board hasn't been generated yet! We're working on it!
If you prefer, you can use the soldering pads on the back of the module to manually connect:
IO8 (Default SDA pin)SDA
IO9 (Default SCL pin)SCL
3.3V3V3
GNDGND
