Inputronic Keyboard - Hardware details
Pinout​
Pin details​
VCCPowerSupply voltage (1.65V to 3.6V supported)
GNDGroundCommon ground for power and signals
SDADataI²C data line for communication
SCLClockI²C clock line for communication
INTInterruptActive-low interrupt output (open-drain)
RESETResetActive-low reset input
This board operates at 1.65V to 3.6V logic levels and is compatible with both 3.3V and 5V systems when used with appropriate level shifters or directly with 3.3V microcontrollers!
Qwiic​
EasyC/qwiic cable
I²C Address​
The TCA8418 has a fixed 7-bit I²C address:
0x34 (0b0110100)
Unlike some I²C devices, the address on this board cannot be changed through hardware jumpers.
Dimensions​
  • Board Dimensions: 136 x 60 mm
  • Header Pin Holes: 1.5 mm
Jumper Details​
This board contains hardware jumpers. See below for their locations and functions:
Loading carousel...
JumperDefault StateFunction
JP1Normally openOptional 3.3V power connection
JP2Normally openReset button connection option
The keyboard matrix is pre-configured with 80 tactile switches arranged in an 8×10 matrix. All switches are connected to the TCA8418 chip's ROW and COL pins internally.
Hardware repository​
CAD files​
Schematic​
BOM (Bill of Materials)​
3D files​
Gerber files​
Compliance​
