Inputronic Keyboard - Getting started
Arduino library​
Inputronic Keyboard Arduino library
Inputronic Keyboard Arduino library by Soldered
Getting started with Arduino
Connections​
QwiicQwiic
If you prefer, you can use I²C pins to manually connect:
IO21 (Default SDA pin)SDA
IO22 (Default SCL pin)SCL
3V33V3
GNDGND
