ESPFlash Programmer - Overview
ESPFlash Programmer​
The ESPFlash Programmer is your go-to solution for fast, hassle-free programming of ESP8266 and ESP32 microcontroller boards. Designed with simplicity and reliability in mind, it eliminates the need for manual button pressing or external circuitry.
Just plug a USB-C cable into the ESPFlash Programmer, connect it to your ESP board, and you're ready to go. All the necessary electronics, including those that manage signal timing and boot mode activation, are built right in. It automatically handles the reset and boot sequence required to enter programming mode, making firmware uploads smooth and straightforward.
Optimized for Soldered's own boards that feature the ESPFlash programming header, the ESPFlash Programmer is also fully compatible with any ESP8266 or ESP32 board that lacks a built-in USB-to-UART converter.
Whether you're prototyping or flashing firmware at a large scale, the ESPFlash Programmer streamlines the process, so you can spend less time debugging connections and more time building.
ESPFlash Programmer
ESPFlash Programmer
ESPFlash ESP32 Programmer
333398
Key Features​
  • IC: CH340C
  • USB: Type-C
  • Dimensions: 38 × 22 mm (1.5 × 0.9 inch)
