Inkplate 2 – Printing text
Printing text on Inkplate is simple and requires only a few functions. The library also supports custom fonts of different sizes.
To print text, use setCursor followed by print. If you're using the default font, you can use setTextSize to increase the font size:
from inkplate2 import Inkplate # Include the Inkplate module
inkplate = Inkplate() # Create an instance of the display
inkplate.begin() # Initialize the display
inkplate.set_text_size(2) # Scale up the font size
inkplate.set_cursor(25,35) # Set the cursor from where the text will be written
inkplate.print("Hello world") # Print text to frame buffer
inkplate.display() # Display what is drawn to the buffer
Hello world output on display
inkplate.set_text_size()
Increases the text size by a given factor.
Returns value: None
intsSize factor. 1 is default size, 2 is twice as large, 3 is three times larger, etc.
inkplate.set_cursor()
Move the cursor to point at given position on the screen starting from the upper left corner.
Returns value: None
intxX coordinate value
intyY coordinate value
inkplate.print()
Prints text at the previously set cursor position. This is the standard print function.
Returns value: None
chartextString to print on the display.
Alternative fonts example​
Here we will print text using different fonts on our Inkplate board. All of the fonts are available on Inkplate-MicroPython GitHub, just upload .py file to your board and import it in your code:
# Import custom fonts
import free_serif_bold_italic_18px as SerifBoldItalic
import free_sans_bold_oblique_32px as SansBoldOblique
# Create Inkplate object
inkplate.begin()
# Set custom fonts and print example text
inkplate.set_font(SerifBoldItalic)
inkplate.set_cursor(5, 5)
inkplate.print("Serif Bold Italic")
inkplate.set_font(SansBoldOblique)
inkplate.set_cursor(5, 30) # The 32px font is much taller, so give it its own line
inkplate.print("Sans Bold")
# Display from buffer
inkplate.display()
Custom Fonts Example
Custom fonts​
Alternatively, if you want to create your own custom font to use on your board, take a .ttf or .otf font and turn it into a Python bytearray using the following command:
python font_to_py.py SourceSans3-Regular.ttf 20 output.py
where number 20 represents maximum font size.
This external python script can be found on this GitHub repo.
Example of custom font​
import drippy as drippy
# Create object and initialize Inkplate
inkplate.begin()
# Set custom font and print text
inkplate.set_font(drippy)
inkplate.set_cursor(5, 40)
inkplate.println("Drippy")
# Update the display
inkplate.display()
Drippy Custom Font Example
Full examples​
hello_world.py
Displays 'Hello world!' text on the Inkplate 2 screen.
custom_font.py
Swap in one of the extra typefaces shipped under fonts/ instead of the default font.
