BHI385 Smart IMU - Hardware details
Pinout​
BHI385 Smart IMU Breakout Pinout
Pin details​
INTInterruptActive interrupt output from the BHI385 HIRQ pin (3.3V logic)
GNDGroundCommon ground for power and signals
3V3Power3.3V supply input
SCLClockI2C clock line (3.3V level, level-shifted to 1.8V on board)
SDADataI2C data line (3.3V level, level-shifted to 1.8V on board)
This board operates from a 3.3V supply. An onboard regulator generates the 1.8V rail required by the BHI385, and a dual NMOS level-shifter translates I2C signals between the 1.8V sensor domain and the 3.3V host interface. The board is not directly 5V-tolerant on the I2C lines without an external level-shifter.
Qwiic (formerly easyC)​
EasyC/qwiic cable
Dimensions​
  • Board Dimensions: 22 × 22 mm (0.87 × 0.87 in)
  • Header Pin Holes: 1.5 mm
Jumper Details​
Loading carousel...
JumperDefault StateFunction
JP1NC (Normally closed)Connects the 3.3V-side pull-up resistors (both SDA and SCL) on the I2C level-shifter to the 3V3 rail.
JP2NC (Normally closed)Connects the 1.8V-side pull-up resistors (both SDA and SCL) on the I2C level-shifter to the 1.8V rail.
JP3NO (Normally open)Connects the 3.3V rail to the input of the onboard LDO regulator. Bridge to power the LDO from 3V3; leave open to isolate the regulator input.
JP4NC (Normally closed)Connects the EN pin of the onboard regulator to the 3.3V rail, enabling the regulator.
JP50x29Selects the I2C address: bridge towards 0x29 (HSDO = VDDIO, default) or 0x28 (HSDO = GND).
Hardware repository​
CAD files​
Schematic​
BOM (Bill of Materials)​
3D files​
Gerber files​
Gerber files are essential for PCB manufacturing. The repository includes copper layers, solder mask, silkscreen, paste layers, drill files, board outline, and the Gerber job file.
Compliance​
The Compliance section includes CE, UKCA, Safety Instructions, and an Info.txt file.
