BHI385 Smart IMU - Getting started
Arduino library​
Soldered BHI385 IMU Arduino Library
Arduino library for the Bosch BHI385 Smart IMU: firmware upload, virtual sensor enable/disable, and FIFO-based data readout.
Getting started with Arduino
Getting the firmware binary​
The BHI385 has no internal flash. The sensor firmware must be uploaded from your sketch on every power-on. The firmware binary is distributed by Bosch Sensortec as part of their SensorAPI package and is not bundled with this library due to licensing.
To get it:
  1. Download the BHI385 SensorAPI from Bosch Sensortec's GitHub.
  2. Inside the package, locate the firmware header file (e.g. BHI385_firmware.h or a .fw.h variant from the firmware/ folder).
  3. Copy that header file into your Arduino sketch folder alongside your .ino file.
  4. Include it in your sketch with #include "BHI385_firmware.h".
Without the firmware header, loadFirmware() cannot be called and no virtual sensors will produce data. Make sure the file is in your sketch folder before uploading.
Connections​
Below is an example connection diagram for NULA DeepSleep. These pins will be used in the examples throughout this documentation.
NULA DeepSleepBHI385 Breakout
QwiicQwiic
