Inputronic BRIDGE - Interrupt-driven reading
The basic example calls pollEvents() on every loop() iteration, which runs a bus transaction even when no new input has arrived. The BRIDGE can instead notify the host only when data is ready. When you enable interrupt mode, the BRIDGE pulses its INT pin as soon as a new HID event is parsed, and pollEvents() returns immediately without any bus traffic until that pin fires.
Connections for this example​
This example uses the same I2C connection as the basic example, with one addition: the INT pin of the BRIDGE is wired to a digital pin on the host.
Nula DeepSleepInputronic BRIDGE
IO8SDA
IO9SCL
IO4INT
Interrupt mode requires the INT pin of the BRIDGE to be wired to a digital pin on the host. In this example the INT pin is connected to IO4 on the Nula DeepSleep. For the full connection tables, see the Getting started page.
Enabling interrupt mode​
You enable interrupt mode through the extra parameters of begin(). Set the enable flag to true, pass the host pin connected to INT, and set the edge: false for a FALLING edge, true for a RISING edge. Optionally, register a callback with onDataReady() that runs inside the interrupt service routine when the BRIDGE signals new data.
#include "Inputronic-BRIDGE.h"
InputronicParser parser;
// Host pin connected to the BRIDGE INT output.
static const int8_t INTERRUPT_PIN = 4;
// Flag set by the ISR callback and checked in loop().
volatile bool newDataFlag = false;
// Runs inside the ISR when the BRIDGE signals new data.
// Keep it short: no Serial or blocking calls here.
void onBridgeDataReady()
newDataFlag = true;
Wire.begin(8, 9);
parser.configureI2c(0x50);
// Enable interrupt mode: enable = true, INT pin = INTERRUPT_PIN,
// trigger on FALLING edge (activeHigh = false).
if (!parser.begin(InputronicParser::PROTOCOL_I2C, Wire, true, INTERRUPT_PIN, false))
Serial.println("Could not connect to BRIDGE over I2C!");
while (true);
parser.onDataReady(onBridgeDataReady);
Serial.println("BRIDGE connected. Interrupt mode active.");
// Returns immediately without bus traffic unless the INT pin has fired.
auto events = parser.pollEvents();
if (events.keyboard.valid)
Serial.print("Keyboard: ");
for (uint8_t i = 0; i < events.keyboard.keyCount; i++)
Serial.print(events.keyboard.keys[i]);
Serial.println();
if (events.mouse.valid)
Serial.printf("Mouse X:%d Y:%d L:%d R:%d\n",
events.mouse.x, events.mouse.y,
events.mouse.btnLeft, events.mouse.btnRight);
if (newDataFlag)
// The events above already hold the latest data. Use this flag
// to trigger extra work when data arrives.
Interrupt example output from Serial Monitor
parser.begin()
Initializes the parser and enables interrupt-driven polling. pollEvents() then only runs a bus transaction after the INT pin fires.
Returns value: Returns true if the BRIDGE responds to the connection check, false otherwise.
CommProtocolpThe communication protocol to use (e.g., PROTOCOL_I2C, PROTOCOL_UART, PROTOCOL_SPI).
TwoWire &wireReference to the communication bus object (e.g., Wire).
boolenableInterruptSet to true to enable interrupt-driven polling.
int8_tinterruptPinHost pin connected to the BRIDGE INT output.
boolactiveHighInterrupt edge: true fires on RISING, false fires on FALLING.
parser.onDataReady()
Registers a user callback that runs inside the interrupt service routine when the BRIDGE signals new data. The callback must be short and must not call Serial or any blocking function.
Returns value: None
void (*)()callbackPointer to the function to call from the ISR when data is ready.
