Inkplate 6COLOR – Deep Sleep
Deep sleep is how you get a sketch to run for months on a battery. E-paper needs no power to hold its image, so between refreshes the board can sit at about 18 µA.
Simple deep sleep​
When your ESP32 wakes up from deep sleep, it performs a reset and runs main.py again. That means your main script runs again on every wake-up.
Make sure you've uploaded a main.py file to the ESP32. Put the code you want to run after each wake-up inside it.
Basic example of keeping a counter in RTC memory using raw bytes while ESP32 is in deep sleep.
from inkplate6_color import Inkplate
import machine
# Create a RTC object that stores states between deep sleep cycles
rtc = machine.RTC()
# Read stored bytes from memory
raw = rtc.memory()
# If we have at least 1 stored byte, set as counter,
# otherwise start from 0
count = raw[0] if raw and len(raw) >= 1 else 0
inkplate = Inkplate()
inkplate.begin()
inkplate.clear_display()
# Check for reset reason and print message accordingly
if machine.reset_cause() == machine.DEEPSLEEP_RESET:
inkplate.println("Woke up from sleep")
# Increment counter
count = count + 1
else:
count = 1
inkplate.println("Cold boot / soft reset")
# Write one byte back to RTC memory
rtc.memory(bytes([count]))
inkplate.print(f"Count: {count}")
inkplate.display()
# Important delay before going to sleep when writing scripts
# Wait 10 seconds so you can 'catch' it awake to upload new code later on
time.sleep(10)
# Deep sleep for 10 seconds (10000 milliseconds)
machine.deepsleep(10000)
Get the reset cause.
Returns type: machine.CONSTANT
See constants for possible return values.
machine.deepsleep()
Puts the ESP32 into deep sleep for the given number of milliseconds. Call it with no argument to sleep until a wake source fires.
intsleep_time_msDeep sleep duration in milliseconds
Wake on button press​
import esp32
import machine
# Define a wake up pin on GPIO 36 (wake button)
wake1 = machine.Pin(36, mode = machine.Pin.IN)
# Set ext0 as a wake up source when pin goes LOW
esp32.wake_on_ext0(pin = wake1, level = esp32.WAKEUP_ALL_LOW)
print('Im awake. Going to sleep in 10 seconds')
time.sleep(10)
print('Going to sleep now')
machine.deepsleep()
esp32.wake_on_ext0()
This function uses the external wakeup feature of the RTC_IO peripheral.
Returns type: none
machine.PinPinGPIO number used as wakeup source. Only GPIOs with RTC functionality can be used.
intlevelThe input level that triggers wake-up
Full example​
deep_sleep.py
Count deep sleep cycles using RTC memory and show the count on the screen.
