Getting started
Arduino library​
Soldered WS2812B Grid Arduino Library
Arduino library for the Soldered Smart LED WS2812B Grid 8×8.
Getting started with Arduino
Connections​
The board exposes three signals on its header pins: VCC, GND, and DIN (data in). Below is an example connection for Nula DeepSleep. These pins are used in all examples throughout this documentation.
Nula DeepSleepWS2812B Grid
IO5DIN
5VVCC
GNDGND
[Dodati sliku konekcije]
Chaining multiple grids​
The board also exposes a DOUT header pin. To chain two or more grids together, connect the first board's DOUT to the second board's DIN, and pass the same VCC and GND rails to all boards. Set the total grid width or height in the WS2812Grid constructor to match your physical arrangement.
