Inkplate 10 – Drawing graphics
Inkplate 10 allows you to draw graphics on a 1200 x 825px canvas.
Adafruit GFX is the graphics library included in the Inkplate library for drawing graphics. For more details, refer to the official repository:
Adafruit GFX Library
The core graphics library for Inkplate library, created by Adafruit.
Drawing geometric shapes​
Below is an example demonstrating functions used for drawing graphics on the Inkplate 10:
The color parameter in these functions depends on the display mode. In black-and-white mode, use BLACK or WHITE. In grayscale mode, use values from 0 to 7. Refer to the display modes page for more details.
#include "Inkplate.h"
Inkplate display(INKPLATE_3BIT);
display.begin();
display.clearDisplay();
display.display();
// Draw a pixel
display.drawPixel(100, 50, 0);
// Draw a line
display.drawLine(0, 0, 1023, 757, 1);
// Draw a rectangle
display.drawRect(100, 100, 200, 200, 2);
// Draw a filled rectangle
display.fillRect(300, 100, 200, 300, 3);
// Draw a circle
display.drawCircle(512, 100, 75, 4);
// Draw a filled circle
display.fillCircle(512, 100, 75, 5);
// Draw a rounded rectangle
display.drawRoundRect(310, 300, 400, 300, 10, 4);
// Draw a filled rounded rectangle
display.fillRoundRect(310, 300, 400, 300, 10, 3);
// Draw a triangle
display.drawTriangle(300, 500, 700, 500, 512, 200, 2);
// Draw a filled triangle
display.fillTriangle(350, 467, 650, 467, 512, 250, 1);
// Update the display to render the drawings
display.display();
Below are the detailed references for these functions:
display.drawPixel()
Draws a single pixel on the display at the specified coordinates.
Returns value: none
intxThe x-coordinate of the pixel.
intyThe y-coordinate of the pixel.
uint8_tcolorThe color of the pixel.
display.drawLine()
Draws a straight line between two points on the display.
Returns value: none
intx0The x-coordinate of the starting point.
inty0The y-coordinate of the starting point.
intx1The x-coordinate of the ending point.
inty1The y-coordinate of the ending point.
uint8_tcolorThe color of the line.
display.drawRect()
Draws a rectangle outline on the display.
Returns value: none
intxThe x-coordinate of the top-left corner.
intyThe y-coordinate of the top-left corner.
intwidthThe width of the rectangle.
intheightThe height of the rectangle.
uint8_tcolorThe color of the rectangle outline.
display.fillRect()
Draws a filled rectangle on the display.
Returns value: none
uint8_tcolorThe fill color.
display.drawCircle()
Draws a circle outline on the display.
Returns value: none
intxThe x-coordinate of the circle center.
intyThe y-coordinate of the circle center.
intradiusThe radius of the circle.
uint8_tcolorThe color of the circle outline.
display.fillCircle()
Draws a filled circle on the display.
Returns value: none
display.drawRoundRect()
Draws a rounded rectangle outline on the display.
Returns value: none
intradiusThe radius of the rounded corners.
display.fillRoundRect()
Draws a filled rounded rectangle on the display.
Returns value: none
display.drawTriangle()
Draws a triangle outline on the display.
Returns value: none
intx0The x-coordinate of the first vertex.
inty0The y-coordinate of the first vertex.
intx1The x-coordinate of the second vertex.
inty1The y-coordinate of the second vertex.
intx2The x-coordinate of the third vertex.
inty2The y-coordinate of the third vertex.
uint8_tcolorThe color of the triangle outline.
display.fillTriangle()
Draws a filled triangle on the display.
Returns value: none
Full example​
Inkplate10_Black_And_White.ino
Example on how to draw simple graphics in black and white mode
Inkplate10_Grayscale.ino
Example on how to draw simple graphics in grayscale
