Inkplate 13SPECTRA MicroPython - GET and POST requests
Inkplate 13SPECTRA can connect to the internet and make HTTP requests. This example demonstrates how to perform a simple GET and POST request using the 'urequests' library, with webhook.site as the test server.
Making a GET request​
This example below fetches data from a webhook.site endpoint and prints the response.
webhook.site will generate a unique URL for your personal use. Use http:// instead of https:// (many MicroPython build do not include TLS support).
# Include needed libraries
import network
import urequests
from inkplate13_spectra import Inkplate
# Enter your WiFi credentials here
ssid = "your ssid"
password = "your password"
#Your personal webhook.site URL (use http://, no leading spaces!)
WEBHOOK_URL ="yout webhook id"
# Function which connects to WiFi
# More info here: https://docs.micropython.org/en/latest/esp8266/tutorial/network_basics.html
def do_connect():
import network
sta_if = network.WLAN(network.STA_IF)
if not sta_if.isconnected():
print("connecting to network...")
sta_if.active(True)
sta_if.connect(ssid, password)
while not sta_if.isconnected():
pass
print("network config:", sta_if.ifconfig())
return True
inkplate=Inkplate()
inkplate.begin()
inkplate.set_text_size(2)
if do_connect():
inkplate.print("Wifi connected")
response=urequests.get(WEBHOOK_URL)
print("GET status:", response.status_code)
print("GET body",response.text)
response.close()
else:
inkplate.print("Wifi failed")
inkplate.display()
Example output displayed in console
get_request.py
Full example showing how to connect to WiFi and perform an HTTP GET request using urequests.
urequests.get()
Perform an HTTP GET request to the given URL.
Returns type: Response
Returns value: Response object with .status_code and .text.
StringurlThe target URL (must start with http://).
Making a POST request​
You can also send data to the server. In this example we will send JSON payload to the webhook URL.
import network
import urequests
import ujson
ssid = ""
password = ""
WEBHOOK_URL =""
def do_connect():
import network
sta_if.active(True)
pass
return True
inkplate=Inkplate()
inkplate.begin()
if do_connect():
data = {"message": "Hello from Inkplate 13SPECTRA!"}
# Perform POST request
try:
response = urequests.post(WEBHOOK_URL, json=data)
print("POST status:", response.status_code)
print("POST body:", response.text)
inkplate.print("POST OK!")
inkplate.display()
response.close()
except Exception as e:
print("POST failed:", e)
inkplate.print("POST failed!")
inkplate.display()
else:
inkplate.display()
POST request logged on webhook.site
Example output displayed on e-paper display
post_request.py
Full example showing how to connect to WiFi and perform an HTTP POST request with a JSON payload using urequests.
urequests.post()
Perform an HTTP POST request to the given URL.
DictjsonDictionary to send as JSON in the request body.
