NEO-M9N-00B - Debug Output
This page contains an example of enabling the library's debug output, which prints the raw UBX packets and internal status messages the library sends and receives. Use this to troubleshoot communication issues or see what's actually happening under the hood.
Initialization​
Include the required libraries and create the module object:
#include <Wire.h>
#include <Soldered-GNSS.h>
Soldered_GNSS myGNSS;
unsigned long lastTime = 0;
int counter = 0;
In the setup() function, initialize the module and turn on debugging:
while (!Serial);
Serial.println("Soldered u-blox GNSS Example - Debug Output");
Wire.begin();
if (myGNSS.begin() == false)
Serial.println(F("u-blox GNSS not detected at default I2C address. Please check wiring. Freezing."));
while (1);
myGNSS.setI2COutput(COM_TYPE_UBX);
myGNSS.enableDebugging(); // Print all debug messages to Serial
// myGNSS.enableDebugging(Serial, true); // Or print only critical messages
myGNSS.begin()
Initializes the GNSS module and establishes I2C communication
Returns value: Boolean value, true if the module is detected and communication succeeds, false otherwise
Prints the library's internal debug messages (UBX packets sent/received, parsing status, errors) to a Serial port
Returns value: None
Stream &debugPortOptional. The Serial port to print debug messages to. Defaults to Serial
boolprintLimitedDebugOptional. When true, only critical messages are printed instead of everything. Defaults to false
Taking measurements​
In the loop() function, the module is polled once per second. Debug messages print alongside the readings, then automatically stop after 20 readings:
if (millis() - lastTime > 1000)
lastTime = millis();
long latitude = myGNSS.getLatitude();
Serial.print(F("Lat: "));
Serial.print(latitude);
long longitude = myGNSS.getLongitude();
Serial.print(F(" Long: "));
Serial.print(longitude);
Serial.print(F(" (degrees * 10^-7)"));
long altitude = myGNSS.getAltitude();
Serial.print(F(" Alt: "));
Serial.print(altitude);
Serial.print(F(" (mm)"));
byte SIV = myGNSS.getSIV();
Serial.print(F(" SIV: "));
Serial.println(SIV);
counter++;
if (counter == 20)
myGNSS.disableDebugging();
Serial monitor debug output
Serial monitor
Reads the current latitude from the GNSS module
Returns value: Long value, latitude in degrees multiplied by 10^-7
Reads the current longitude from the GNSS module
Returns value: Long value, longitude in degrees multiplied by 10^-7
Reads the current altitude from the GNSS module
Returns value: Long value, altitude in millimeters
myGNSS.getSIV()
Reads the number of satellites currently in view
Returns value: Byte value, number of satellites in view
Stops the library from printing debug messages
Returns value: None
Full example​
You can find the full sketch below:
DebugOutput.ino
An example of enabling debug output while reading GPS position data with the NEO-M9N-00B module
