NEO-M9N-00B - Great Circle Distance
This page contains an example of calculating the distance and bearing from the module's current position to a fixed target location, using a great-circle (Haversine-based) distance calculation.
Initialization​
Include the required libraries, create the module object, and add two helper functions for calculating distance and bearing between two coordinates:
#include <Wire.h>
#include <Soldered-GNSS.h>
Soldered_GNSS myGNSS;
long lastTime = 0;
double distanceBetween(long lat1_l, long long1_l, long lat2_l, long long2_l)
// Returns distance in meters between two positions using a great-circle
// calculation on a sphere of radius 6372795 m. Rounding errors of up to
// 0.5% are possible since Earth isn't a perfect sphere.
double lat1 = (double)lat1_l / 10000000.0;
double long1 = (double)long1_l / 10000000.0;
double lat2 = (double)lat2_l / 10000000.0;
double long2 = (double)long2_l / 10000000.0;
double delta = radians(long1 - long2);
double sdlong = sin(delta);
double cdlong = cos(delta);
lat1 = radians(lat1);
lat2 = radians(lat2);
double slat1 = sin(lat1);
double clat1 = cos(lat1);
double slat2 = sin(lat2);
double clat2 = cos(lat2);
delta = (clat1 * slat2) - (slat1 * clat2 * cdlong);
delta = sq(delta);
delta += sq(clat2 * sdlong);
delta = sqrt(delta);
double denom = (slat1 * slat2) + (clat1 * clat2 * cdlong);
delta = atan2(delta, denom);
return delta * 6372795;
double courseTo(long lat1_l, long long1_l, long lat2_l, long long2_l)
// Returns course in degrees (North = 0, West = 270) from position 1 to position 2
double dlon = radians(long2 - long1);
double a1 = sin(dlon) * cos(lat2);
double a2 = sin(lat1) * cos(lat2) * cos(dlon);
a2 = cos(lat1) * sin(lat2) - a2;
a2 = atan2(a1, a2);
if (a2 < 0.0)
a2 += TWO_PI;
return degrees(a2);
In the setup() function, initialize the module:
while (!Serial);
Serial.println("Soldered u-blox GNSS Example - Great Circle Distance");
Wire.begin();
if (myGNSS.begin() == false)
Serial.println(F("u-blox GNSS not detected at default I2C address. Please check wiring. Freezing."));
while (1);
myGNSS.setI2COutput(COM_TYPE_UBX);
myGNSS.saveConfigSelective(VAL_CFG_SUBSEC_IOPORT);
myGNSS.begin()
Initializes the GNSS module and establishes I2C communication
Returns value: Boolean value, true if the module is detected and communication succeeds, false otherwise
Taking measurements​
Set your target coordinates, then in the loop() function the module is polled once per second to compute the distance and bearing to that target:
static const long TARGET_LAT = 400909142, TARGET_LON = -1051849833; // Set your own target: degrees * 10^-7
if (millis() - lastTime > 1000)
lastTime = millis();
long latitude = myGNSS.getLatitude();
long longitude = myGNSS.getLongitude();
Serial.print(F("Lat: "));
Serial.print(latitude);
Serial.print(F(" Long: "));
Serial.println(longitude);
double distanceToTarget = distanceBetween(latitude, longitude, TARGET_LAT, TARGET_LON);
Serial.print(F("Distance to target: "));
Serial.print(distanceToTarget, 2);
Serial.print(F(" (m) "));
double courseToTarget = courseTo(latitude, longitude, TARGET_LAT, TARGET_LON);
Serial.print(F("Course to target: "));
Serial.print(courseToTarget, 1);
Serial.println(F(" (degrees)"));
Serial monitor great circle distance readings
Serial monitor
Reads the current latitude from the GNSS module
Returns value: Long value, latitude in degrees multiplied by 10^-7
Reads the current longitude from the GNSS module
Returns value: Long value, longitude in degrees multiplied by 10^-7
The distanceBetween() and courseTo() helper functions aren't part of the library itself, they're plain C++ math included directly in the sketch, adapted from the widely-used TinyGPSPlus library.
Full example​
You can find the full sketch below:
Great_Circle_Distance.ino
An example of calculating distance and bearing to a target location with the NEO-M9N-00B module
