NEO-M9N-00B - Getting started
Arduino library​
To install the Arduino library, use the Arduino library manager or download it from the GitHub repository:
GPS Breakout NEO-M9N-00B Arduino library
GPS Breakout NEO-M9N-00B Arduino library by Soldered
First time Arduino user? For a detailed tutorial on getting started with Arduino, see this section of our docs:
Getting started with Arduino
Connections​
The NEO-M9N-00B can be wired for I2C, UART, or SPI. Pick the interface that fits your project. All three share the same physical pins on the module (SDA/SCL/TX/RX double as SPI signals), so you only need to wire up the one you're actually using.
The simplest way to connect is over Qwiic, since I2C and UART are both active out of the box, no jumper changes needed:
NULA DeepsleepNEO-M9N-00B
QwiicQwiic
If you prefer, you can wire the I2C pins manually instead:
IO8 (Default SDA pin)SDA
IO9 (Default SCL pin)SCL
3V33V3
GNDGND
UART​
UART is also enabled by default, alongside I2C, no jumper changes needed. Cross-connect the TX and RX lines:
IO43 (TX)RX
IO44 (RX)TX
3V33V3
GNDGND
SPI​
SPI is disabled by default. The module ships in I2C + UART mode, and the SDA/SCL/TX/RX pins only switch to SPI functions once you re-bridge the selectable JP4 jumper on the board to its other position (see Hardware details for more on this jumper). With JP4 re-bridged:
IO10 (Default CS pin)SDA / SPI CS
IO11 (Default MOSI pin)RX / SPI MOSI
IO13 (Default MISO pin)TX / SPI MISO
IO12 (Default SCK pin)SCL / SPI SCK
3V33V3
GNDGND
SPI communication won't work until JP4 is re-bridged to its SPI position. Left at its default position, the module stays in I2C + UART mode and ignores anything sent over these pins as SPI.
Re-bridging JP4 is not enough by itself. You must also open the module in u-center and set the SPI port's input/output protocol to UBX only, otherwise it will not respond to commands over SPI, even with the jumper and wiring correct. See Configuring the module with u-center below.
Configuring the module with u-center​
u-center
u-blox's free desktop application for configuring, monitoring, and debugging u-blox GNSS receivers
u-center connects to the module over UART or a USB-to-serial adapter and shows you live satellite data, message traffic, and every configuration option the module supports. You don't need it for normal I2C or UART use since the library configures everything from your sketch, but it's required to get SPI working, and useful for a few other things too:
  • Getting SPI working (required) - the SPI port's protocol must be set explicitly to UBX, or the module will not respond over SPI. In u-center, open View → Messages View, go to UBX → CFG → PRT, select the SPI target port, and set both In Protocol and Out Protocol to UBX only, then click Send. Use CFG → CFG to save the setting to the module's flash so it persists after a power cycle.
  • Watching raw satellite data - the Messages View shows UBX and NMEA messages as they arrive, which is useful for confirming the module is actually receiving data before you start debugging your own code.
  • Changing constellation or update-rate settings - anything you'd otherwise set with library calls like myGNSS.setNavigationFrequency() can be tested interactively first.
u-center only runs on Windows and needs a serial connection (UART or USB-to-serial), so connect over one of those interfaces for configuration even if you plan to use SPI or I2C in your actual project.
