BHI385 Smart IMU - Game Rotation Vector
This page covers reading orientation as a normalized quaternion from the BHI385's Game Rotation Vector virtual sensor.
Game Rotation Vector (quaternion)​
The Game Rotation Vector fuses accelerometer and gyroscope data to output a normalized quaternion representing the device's orientation. Pitch and roll are absolute (gravity-referenced); yaw drifts over time because there is no magnetometer.
// ... begin() and loadFirmware() as above ...
imu.enableGameRotationVector(100.0f); // 100 Hz
if (imu.update())
if (imu.quatUpdated())
Serial.print("X: "); Serial.print(imu.getQuatX(), 4);
Serial.print(" Y: "); Serial.print(imu.getQuatY(), 4);
Serial.print(" Z: "); Serial.print(imu.getQuatZ(), 4);
Serial.print(" W: "); Serial.println(imu.getQuatW(), 4);
imu.clearUpdatedFlags();
delay(20);
Serial monitor Game Rotation Vector readings
Serial monitor Game Rotation Vector output
imu.enableGameRotationVector()
Enables the Game Rotation Vector virtual sensor, which fuses accelerometer and gyroscope data to produce a normalized quaternion (x, y, z, w). Does not use a magnetometer, so yaw is relative to the device orientation at power-on.
Returns value: true if the sensor was configured successfully
floatrateHzOutput data rate in Hz. Default: 100.0f
imu.getQuatX() / getQuatY() / getQuatZ() / getQuatW()
Returns the specified component of the most recently received normalized quaternion. All four components are in the range -1.0 to +1.0. Valid after update() returns with quatUpdated() true.
Returns value: Quaternion component as a float in range [-1, +1]
