Inkplate 13SPECTRA – Free GPIO pins
Inkplate 13SPECTRA's onboard ESP32-S3-WROOM-2 has some pins reserved for internal use (for example, the connection to the e-paper display) and cannot be used for end-user applications. This page contains a list of the available GPIO pins that can be used for external applications.
If you don't need pin details and are just interested in the pins, here are the Inkplate 13SPECTRA pins that are not connected to any onboard component: IO17, GPIO Expander: P0-0 to P0-7, P1-0, P1-3 to P1-7
Inkplate 13SPECTRA free GPIO pins highlighted
Inkplate 13SPECTRA ESP32 header
Free pin table​
PINCONNECTED TOFUNCTION
TXDCH340UART transmit pin, used to upload code and for Serial communication over USB
RXDCH340UART receive pin, used to upload code and for Serial communication over USB
IO11SDCARDSPI MOSI line for the onboard microSD card slot
IO12SDCARDSPI SCK (clock) line for the onboard microSD card slot
IO13SDCARDSPI MISO line for the onboard microSD card slot
IO15JP4 Check jumper detailsOpen (not connected) by default. When JP4 is shorted, this pin becomes the microSD card's SPI chip select line
IO16JP1 Check jumper detailsConnected by default (JP1 is normally closed) to the onboard IO expander's interrupt pin
IO17FREENo onboard connection
IO18WAKE buttonPulled high through a resistor and pulled low when the onboard wake button is pressed
IO0Auto-reset circuitDriven low through the auto-reset circuit (alongside DTR/RTS) to enter the bootloader during upload; also an ESP32-S3 strapping pin, so avoid holding it low at boot for other purposes
IO2JP2 Check jumper detailsOpen (not connected) by default. When JP2 is shorted, this pin is connected to the onboard RTC's clock output
P0-0 to P0-7FREEGeneral-purpose IO expander pins, controlled over I2C
P1-0FREEGeneral-purpose IO expander pin, controlled over I2C
P1-1JP5 Check jumper detailsOpen (not connected) by default. When JP5 is shorted, this pin connects to the battery voltage measurement circuit
P1-2JP6 Check jumper detailsConnected by default (JP6 is normally closed) to the MOSFET that powers the onboard microSD card
P1-3 to P1-7FREEGeneral-purpose IO expander pins, controlled over I2C
INTIO16 Check jumper detailsIO expander interrupt output, pulled up onboard; connected to ESP32 IO16 when JP1 is shorted
