Inkplate 2 – Draw Image from Web
This example shows how to connect to WiFi and render an image fetched from a URL using drawImage.
Supported image formats: JPG, BMP, and PNG.
JPG files without progressive encoding are supported.
If you experience issues displaying an image, try re-saving it with an image editing program. The issue is usually related to the image format.
Drawing an Image​
Example image
Example image to display on Inkplate
from inkplate2 import Inkplate
import network
# WiFi credentials (replace with your own)
SSID = "YOUR_SSID_HERE"
PASSWORD = "YOUR_PASSWORD_HERE"
# Create Inkplate object in 2-bit (grayscale) mode
inkplate = Inkplate()
inkplate.begin()
# Connect to WiFi (process explained on previous pages)
if not do_connect():
raise SystemExit("WiFi connection failed")
# Example usage
drawLenght=time.ticks_ms()
inkplate.draw_image(
"https://i.imgur.com/VSRtgBr.jpeg", # URL to image
0, 0, # X, Y position
dither = True # Enable/Disable dithering
# Show the image from the internal buffer
inkplate.display()
Example image displayed on Inkplate with Dithering enabled
Example image displayed on Inkplate without Dithering
inkplate.draw_image()
This function draws an image from the specified char path (either web URL or local file path)
Returns value: None
stringpathPath and filename of the image. Can be a URL (for web images) or a local file path.
intx0X-coordinate of the image's upper-left corner in the framebuffer.
inty0Y-coordinate of the image's upper-left corner in the framebuffer.
boolinvertIf true, inverts colors.
boolditherDithering mode: 0 (disabled), 1 (enabled).
intkernel_typeSpecifies dithering algorithm to use.
Available options for dithering algorithm:
AlgorithmValue
Inkplate.KERNEL_FLOYD_STEINBERG0
Inkplate.KERNEL_JJN1
Inkplate.KERNEL_STUCKI2
Inkplate.KERNEL_BURKES 3
Performance Notes
  • JPG: ~3 seconds (or ~5s with dithering)
  • PNG: ~4 seconds (or ~6s with dithering)
  • BMP: ~6 seconds (or ~7s with dithering)
  • Maximum image file size: ~800kB
Full example​
display_image_web.py
Connects to WiFi and renders an image fetched from a URL.
