Inkplate 6FLICK MicroPython - Read and write
The onboard microSD card can be used for reading and writing to data files. This example demonstrates how to create a text file, write to it, and then read the contents back.
Writing and reading a file​
Before running this example, make sure your SD card is formatted as FAT16, FAT32 or exFAT and inserted into Inkplate 6FLICK. To learn how to format the microSD card click here
from inkplate6_flick import Inkplate
import os
inkplate.begin()
inkplate.init_sd_card(fast_boot=True)
#List files on the SD card
print("FIles on SD:",os.listdir("sd"))
#Writing to a file
with open("sd/example.txt","w")as f:
f.write("Hello from Inkplate!\n")
f.write("this text is stored on the SD card.\n")
print("Data written to sd/example.txt")
#Reading from the same file
with open("sd/example.txt","r") as f:
content=f.read()
print("File contents:")
print(content)
open()
Open a file from the microSD card for reading or writing.
Returns type: File object
Returns value: File object that can be read from or written to.
StringpathPath to the file. Must begin with sd/ (without a leading slash).
StringmodeDefines what action will happen to specified file.
All available mode options:
ModeMeaning
"r"Read (default). Opens a file for reading. Errors if the file does not exist.
"a"Append. Opens a file for appending. Creates the file if it does not exist.
"w"Write. Opens a file for writing. Creates the file if it does not exist (overwrites if it does).
"x"Create. Creates a new file. Errors if the file already exists.
"t"Text mode (default). Reads/writes strings.
"b"Binary mode. Reads/writes raw bytes (e.g., images, data files).
Inkplate 6FLICK running the example code
Example output
Full example​
microsd_read_write.py
List, write and read back a text file on the microSD card.
