Inkplate 6FLICK MicroPython - Formatting the microSD card
The built-in microSD card slot on the back of Inkplate 6FLICK can be a great asset for your projects, either for storing a very large number of high-quality images which can be displayed or reading and writing data between deep sleep cycles.
All supported card formats are: FAT16, FAT32, exFAT
All supported card types are: SD, SDHC and SDXC
Preparing the microSD card before usage​
For best results, use the official SD card formatter to format the card to FAT32 before usage.
Official SD card formatter
The official SD Card formatter
Initialization​
Before the microSD card can be used, it must first be initialized. This powers on the microSD card circuitry and performs all the necessary memory allocations:
from inkplate6_flick import Inkplate
from os import listdir
inkplate.begin()
# Note:
# - This function must be called before accessing files on the SD card.
# - The fastboot option has no effect if the device is already running.
inkplate.init_sd_card(fast_boot=True)
inkplate.sd_card_sleep()
inkplate.init_sd_card()
Initialize the onboard microSD card interface, allowing images, fonts, and data files to be loaded from the SD card.
Returns value: Boolean, True if the SD card was successfully initialized, otherwise False.
Booleanfast_bootOptional. If True (default), use faster initialization to reduce startup time.
Puts the microSD card circuitry into low-power sleep mode to save energy when the card is not in use.
