Inkplate 10 MicroPython - Drawing graphics
Inkplate 10 allows you to draw different geometric shapes anywhere on its 1200 x 825px canvas. The shapes can be filled or hollow
Drawing shapes​
Below is a example that demonstrates how to draw basic shapes in Black-White display mode.
If you want to use the grayscale mode, simply change the constructor value and instead of using inkplate.BLACK use a numeric value: 0-3
from inkplate10 import Inkplate
inkplate = Inkplate(Inkplate.INKPLATE_1BIT)
inkplate.begin()
inkplate.clear_display()
inkplate.display()
inkplate.draw_pixel(100, 100, inkplate.BLACK)
inkplate.draw_rect(50, 50, 75, 75, inkplate.BLACK)
inkplate.draw_circle(200, 200, 30, inkplate.BLACK)
inkplate.fill_circle(300, 300, 30, inkplate.BLACK)
inkplate.draw_fast_hline(20, 100, 50, inkplate.BLACK)
inkplate.draw_fast_vline(100, 20, 50, inkplate.BLACK)
inkplate.draw_line(100, 100, 400, 400, inkplate.BLACK)
inkplate.draw_round_rect(100, 10, 100, 100, 10, inkplate.BLACK)
inkplate.fill_round_rect(10, 100, 100, 100, 10, inkplate.BLACK)
inkplate.draw_triangle(300, 100, 400, 150, 400, 100, inkplate.BLACK)
inkplate.display()
inkplate.draw_pixel()
Set a single pixel in the frame buffer.
NumberxX coordinate.
NumberyY coordinate.
ConstcolorColor constant (BLACK or WHITE in BW mode).
inkplate.draw_rect()
Draw an unfilled rectangle outline.
NumberxLeft X.
NumberyTop Y.
NumberwWidth in pixels.
NumberhHeight in pixels.
ConstcolorOutline color.
inkplate.draw_circle()
Draw an unfilled circle.
Numberx0Center X.
Numbery0Center Y.
NumberrRadius in pixels.
inkplate.fill_circle()
Draw a filled circle.
Numberx0Center X.
Numbery0Center Y.
ConstcolorFill color.
inkplate.draw_fast_hline()
Draw a horizontal line quickly.
NumberxStart X.
NumberyY position.
NumberwLine width in pixels.
ConstcolorLine color.
inkplate.draw_fast_vline()
Draw a vertical line quickly.
NumberxX position.
NumberyStart Y.
NumberhLine height in pixels.
inkplate.draw_line()
Draw a line from one point to another.
Numberx0Start X.
Numbery0Start Y.
Numberx1End X.
Numbery1End Y.
inkplate.draw_round_rect()
Draw an unfilled rectangle with rounded corners.
NumberxLeft X.
NumberyTop Y.
NumberradiusCorner radius in pixels.
inkplate.fill_round_rect()
Draw a filled rectangle with rounded corners.
NumberxLeft X.
NumberyTop Y.
inkplate.draw_triangle()
Draw a triangle outline using three vertices.
Numberx0Vertex A X.
Numbery0Vertex A Y.
Numberx1Vertex B X.
Numbery1Vertex B Y.
Numberx2Vertex C X.
Numbery2Vertex C Y.
Inkplate 10 running the example code
Simple predefined shapes.
Full examples​
basic_bw.py
Draw basic black and white shapes and a Soldered logo bitmap.
basic_grayscale.py
Draw different shades of gray in grayscale mode and display a Soldered logo bitmap.
