Inkplate 10 MicroPython - Initialization and display update
Initializing Inkplate​
Here is a basic Inkplate object creation and display initialization which we will use in every example in following tutorials:
from inkplate10 import Inkplate
# Create Inkplate object
inkplate.begin()
# Clear the display buffer
inkplate.clear_display()
# Draw what is currently stored in frame buffer, needs to be called to update the display
inkplate.display()
inkplate=Inkplate()
Creates the Inkplate object, in this example we are using enum Inkplate.INKPLATE_1BIT to set the display mode in Black and White mode.
NumbermodeEnum representation of a integer value that sets the display mode as either Black-White or Grayscale.
To learn more about Grayscale mode, check this documentation
VALUEENUM
Black-White modeINKPLATE_1BIT
GrayscaleINKPLATE_2BIT
inkplate.begin()
Initializes the display, this must be called only once after creating the Inkplate object.
Clears the internal frame buffer (does not change the panel until you update).
inkplate.display()
Performs a full-screen refresh, sending the current frame buffer to the panel.
Full example​
hello_world.py
Display text on the screen.
