Inkplate 10 MicroPython - Printing text
Inkplate 10 allows you to print text on a 1200 x 825 px canvas.
Displaying basic information​
Below is a simple example demonstrating the simple way of displaying the information on the Inkplate display.
from inkplate10 import Inkplate
inkplate = Inkplate(Inkplate.INKPLATE_1BIT)
inkplate.begin()
inkplate.clear_display()
inkplate.display()
#Putting the text in display buffer
inkplate.print("Hello World!")
inkplate.display()
inkplate.print()
Puts the text in display buffer at the current position on display
StringtextString to render.
Inkplate 10 running the example code
Displaying text in grayscale and more text parameters​
Inkplate 10 also lets you render grayscale graphics on its canvas, with 8 levels from 0 to 7. You can also modify different text parameters, such as: text color, text size and text wrapping. Below is a simple example demonstrating different text colors using grayscale and different text styles:
The display mode constant is called INKPLATE_2BIT, but the panel actually gives you 8 levels of gray, not 4. Values run from 0 to 7.
The color parameter in set_text_color() changes text color as per the table below:
VALUECOLOR
0Black
1Very dark grey
2Dark grey
3Mid dark grey
4Mid light grey
5Light grey
6Very light grey
7White
# Create Inkplate object in 2-bit grayscale mode
inkplate = Inkplate(Inkplate.INKPLATE_2BIT)
inkplate.begin()
# Clear the frame buffer
inkplate.display()
inkplate.set_cursor(50, 50)
inkplate.set_text_size(1)
inkplate.set_text_color(0) # darkest text (black)
inkplate.print("Size 1")
inkplate.set_cursor(50, 100)
inkplate.set_text_size(2)
inkplate.set_text_color(1) # very dark gray
inkplate.print("Size 2")
inkplate.set_cursor(50, 180)
inkplate.set_text_size(3)
inkplate.set_text_color(2) # dark gray
inkplate.print("Size 3")
inkplate.set_text_color(3) # mid gray
long_text = (
"This is a very long line of text intended to demonstrate how wrapping works. "
"When wrap mode is enabled, the text will continue onto the next line once it "
"reaches the edge of the display. This makes it possible to write paragraphs "
"or larger blocks of text without worrying about manually inserting line breaks. "
"It is especially useful for rendering user interfaces, menus, or e-books."
inkplate.set_cursor(50, 340)
inkplate.set_text_wrapping(True)
inkplate.print(long_text)
inkplate.set_cursor(50, 460)
inkplate.set_text_wrapping(False)
inkplate.display()
inkplate.set_cursor()
Set the cursor position for the next text to be rendered.
NumberxX coordinate for the text start.
NumberyY coordinate for the text baseline.
inkplate.set_text_size()
Set the text size scaling factor.
NumbersizeScale factor (1 = normal, 2 = double, 3 = triple, …).
inkplate.set_text_color()
Set the text color (grayscale level) used for text rendering.
NumbercolorGrayscale value for text, from 0 (black) to 7 (white) in grayscale mode.
inkplate.set_text_wrapping()
Enable or disable automatic text wrapping when reaching the display edge.
Returns value: Nothing
BooleanwrapTrue to wrap text, False to let it continue off-screen.
Simple grayscale example with different text styles.
Full examples​
hello_world.py
Display text on the screen.
custom_font.py
Swap in one of the extra typefaces shipped under fonts/ instead of the default font.
