Inkplate 13SPECTRA MicroPython - Draw Image from microSD card
Inkplate 13SPECTRA can load and render images directly from the onboard microSD card. This example shows how to initialize the SD card, list its contents and display a JPEG, PNG or BMP image on screen.
Displaying an image from the SD card​
Before running this example, make sure your SD card is formatted as FAT16, FAT32 or exFAT and inserted into Inkplate 13SPECTRA. To learn how to format the microSD card click here
The picture used in the example can be downloaded directly from the Inkplate MicroPython Library.
from inkplate13SPECTRA import Inkplate
from os import listdir
# Create Inkplate object
inkplate = Inkplate()
inkplate.begin()
# Initializes the SD card.
# Parameters:
# - fastboot (bool, default=False):
# If True, performs a soft reboot immediately after SD card initialization
# (only on cold start or hard reset). This significantly improves SD card
# read speeds, typically doubling performance.
# Note:
# - This function must be called before accessing files on the SD card.
# - The fastboot option has no effect if the device is already running.
inkplate.initSDCard(fastBoot=True)
# This prints all the files on card
print(listdir("/sd"))
# Draw an image on the screen.
# Parameters:
# - path: File path to the image. Supports local paths (e.g., from SD card) or URLs.
# Supported formats: JPG, PNG, BMP.
# - x0: X-coordinate of the top-left corner where the image will be displayed.
# - y0: Y-coordinate of the top-left corner where the image will be displayed.
# - invert (bool, default=False): If True, inverts the image colors.
# - dither (bool, default=False): If True, applies a dithering algorithm to the image for better grayscale rendering.
# - kernel_type (int): Specifies the dithering algorithm to use.
# Available options:
# Inkplate.KERNEL_FLOYD_STEINBERG = 0
# Inkplate.KERNEL_JJN = 1
# Inkplate.KERNEL_STUCKI = 2
# Inkplate.KERNEL_BURKES = 3
# Performance Notes:
# - JPG: ~52 seconds (or ~90s with dithering)
# Example usage:
inkplate.drawImage("sd/image.jpg", 0, 0, invert=False, dither=True, kernel_type=Inkplate.KERNEL_FLOYD_STEINBERG )
# Show the image from the buffer
inkplate.display()
inkplate.SDCardSleep()
# To turn it back on, use:
# inkplate.SDCardWake()
Example output displayed on e-paper display
inkplate.drawImage()
Draw an image from a file path or URL into the display buffer.
StringpathPath to image (e.g. "sd/image.jpg") or URL.
Numberx0X coordinate of the top-left corner.
Numbery0Y coordinate of the top-left corner.
BooleaninvertIf True, invert image colors.
BooleanditherIf True, apply dithering for better grayscale rendering.
Constantkernel_typeDithering algorithm. Options: Inkplate.KERNEL_FLOYD_STEINBERG, Inkplate.KERNEL_JJN, Inkplate.KERNEL_STUCKI, Inkplate.KERNEL_BURKES.
Available options for dithering algorithm:
AlgorithmValue
Inkplate.KERNEL_FLOYD_STEINBERG0
Inkplate.KERNEL_JJN1
Inkplate.KERNEL_STUCKI2
Inkplate.KERNEL_BURKES 3
Performance Notes
  • JPG: ~3 seconds (or ~14s with dithering)
  • PNG: ~9 seconds (or ~19s with dithering)
  • BMP: ~20 seconds (or ~40s with dithering)
  • Maximum image file size: ~800kB
