Inkplate 6 MicroPython - GET and POST requests
Inkplate 6 can connect to the internet and make HTTP requests. This example demonstrates how to perform a simple GET and POST request using the 'urequests' library, with webhook.site as the test server.
Making a GET request​
The example below fetches data from a webhook.site endpoint and prints the response.
Webhook.site will generate a unique URL for your personal use. Use http:// instead of https:// (many MicroPython builds do not include TLS support).
import network
import urequests
from inkplate6 import Inkplate
# Your WiFi credentials
SSID = "YourNetwork"
PASSWORD = "YourPassword"
# Your personal webhook.site URL (use http://, no leading spaces!)
WEBHOOK_URL = "http://webhook.site/your-unique-url"
def connect_wifi():
sta_if = network.WLAN(network.STA_IF)
if not sta_if.isconnected():
sta_if.active(True)
sta_if.connect(SSID, PASSWORD)
start = time.ticks_ms()
while not sta_if.isconnected():
if time.ticks_diff(time.ticks_ms(), start) > 10_000:
print("WiFi connection failed")
return False
time.sleep(0.5)
return True
if connect_wifi():
print("Connected to WiFi")
# Perform GET request
response = urequests.get(WEBHOOK_URL)
print("GET status:", response.status_code)
print("GET body:", response.text)
response.close()
urequests.get()
Perform an HTTP GET request to the given URL.
Returns type: Response
Returns value: Response object with .status_code and .text.
StringurlThe target URL (must start with http://).
Inkplate 6 running the example code
Example code output.
Making a POST request​
You can also send data to the server. In this example we will send JSON payload to the webhook URL.
import network
import urequests
import ujson
def connect_wifi():
print("Connecting to WiFi...")
sta_if.active(True)
return False
time.sleep(0.5)
print("Connected:", sta_if.ifconfig())
return True
# Initialize Inkplate display
inkplate = Inkplate(Inkplate.INKPLATE_1BIT)
inkplate.begin()
inkplate.clear_display()
inkplate.display()
inkplate.set_text_size(2)
inkplate.set_cursor(50, 100)
if connect_wifi():
# Data to send
data = {"message": "Hello from Inkplate 6!"}
# Perform POST request
try:
response = urequests.post(WEBHOOK_URL, json=data)
print("POST status:", response.status_code)
print("POST body:", response.text)
inkplate.print("POST OK!")
inkplate.display()
response.close()
except Exception as e:
print("POST failed:", e)
inkplate.print("POST failed!")
inkplate.display()
else:
inkplate.print("WiFi failed!")
inkplate.display()
urequests.post()
Perform an HTTP POST request to the given URL.
DictjsonDictionary to send as JSON in the request body.
POST request message on webhook.site.
Full examples​
get_request.py
Connect to WiFi and perform an HTTP GET request using urequests.
post_request.py
Connect to WiFi and perform an HTTP POST request with a JSON payload using urequests.
